At this time it I've haven't done my homework on what these parts are worth until you make me an offer + I will give better price on YOU purchasing more than 1 part.
I accept Paypal (turbobuick4@yahoo.com)
You can call me with any questions
Fred @ 813-451-4242
All Parts are used unless specified & sold as is.
I'm trying to be fair who gets what first,but between PM's,POST's,Emails, & Phone Calls ,someone going to get upset because they said they inquired 1st.
Communicate & make payment ASAP & the parts are yours.
Here is a description of the following parts in the pics provided:
Front License Plates (3 pieces)-$15
Up Pipe-Drilled for Alky-$19
2-Intercooler Mounting Brackets,1 is cut,the other is not-$19
More Seat Trim Pieces
Rear View Mirror W/Map Lights (a must for T-Top Cars)-$19-SOLD
A/C Control Head-$19
Blue Center Console Door-$15
Brand New-Cam Button(comp cams) & Cam Tensioner W/Spring (cloyes)-$15
2-Valve Cover Oil Neck, 1 w/small K & N Filter (can also use filter in front of passenger side valve cover)
2-End Caps for Spoiler-$19
4-Retractable Seat Belts(probally all rears)
Brand New-GM Hose-SOLD
Hood Insulation Pad Lock Buttons-$9
Motor Torque Tie Down Strap-$19
New-Mass Air Bracket (to mount to sensor to hold in placing when removing stock air cleaner)-$9
New-Hypertech Power Chip (requires 160 thermostat,probally worth something as a classic)-$19 Sold
New-King Main Bearings .010
These King AM-Series main bearings are recommended for street or marine applications. These King AM-Series main bearings have superior embedability, which provides greater macro-particle that reduces scratching of the crank journals and tearing or weakening of the Babbitt overlays. These King AM-Series main bearings feature tolerance control up to plus or minus .0001 and are lead-free, making them environmentally friendly and user-safe.-$29
Ashtray w/Lighter-$9
Stainless Wipe Blade Holders-$15
Instrument Switch's (Defrost,Sentinel Door Chime)-$15 for all
Estheon covers(mis-spelled,but covers the door straps where they screw down)-$9 SOLD
Silicon Reducers/Couplers, 2 1/2" x 3"(4" long), 3" x 4"(3" long), 3 1/2" x 4"(4" long),
3" x 4" (blue,4" long)& 5 T Bolt Clamps-Would prefer to sell them as a set instead , ALL for $39
Overflow Reservoir w/Cap & Hose-$20-SOLD
1/2" Plenum Spacer-$25-SOLD
2-Wide Band O2 Sensors (its what Innovative uses)-SOLD
4- ACDelco GNX O2 Sensors (quicker than stock ones)$10 each or all four for $29
Stock Wastegate-$15
Heater Valve-$9 SOLD
2-Stock Fuel Pressure Regulator-$9 each
Fuel Pressure Chrome Line-$9
VDO EGT Guage-$15
Autometer Oil Pressure Guage(goes to 100 psi)-$15
Thermostat Housing w/Hold Down Bracket-$15
Breather (small) Fits in front of passenger valve cover
4-Metal Headlight Bezels-$30
Package of Window Moulding Trim Clips-$9
Transmission Inspection Cover-$29
Tire Iron
Spare Tire Hold Downs
2-Vent/Ac-$9 for both SOLD
2-Stock Tranny Pan, 1 has zero dents on bottom-$35,the other has 2 small dents on bottom-$20
Flywheel-$25
