NGK Coil Pack?
BASS
I see that NGK sells the coil pack for our cars.
Anyone using these or know how they compare with the stock GM/AC Delco units?
Truthfully bud I would save your money and get a TR6 . The coil that it uses throws a hotter spark and you have the option of going individual coil if you wanted . If the ignition module goes out I believe they are around $200 to replace which sucks . That setup is probably the best ignition upgrade you can do on a turbo Buick In my opinion
Not yet. I closed the plug gaps from .034 to .028. That seems to have helped quite a bit.
