G
GPZ406
Guest
My a/f ratio is set at 12.9 n/a and corrects less than 5%.I have a wet kit that`s not controlled by speed-pro(yet). Should I disable the correction when the n2o is activated? I assume the extra fuel would cause the ecu to go leaner trying to maintain12.9 as programmed which is a bad thing.How should I set up the ecu so everything works properly on n2o?What is a good target a/f for 150 shot?Right now it`s pulling out 25% fuel and the actual o2 reading is 12.5!!How did I not hurt something ??I went from 117 mph to 129.5 under these conditions on pump gas and additive with 28 degrees timing down from 35. Any thoughts? the car is a 91 Z28 with a 9.5/1 406,I know its not a Buick but this is THE BEST place for info using this awsome system.
Thanks again!!!!!
Glen
Thanks again!!!!!
Glen
