Kevin Cribbs
- Aug 4, 2012
After letting the car sit for awhile the A/C stopped working. I have went through all of the typical problems and have figured out there is no 12V going to the compressor. I have jumped the low pressure switch and the a/c relay kicks on. The relay is good but I also jumped it to make sure that wasn't it. The ac fuse and ecm sol fuse are good. The wiring harness looks ok so I didn't dig into that to trace it down. I plan on refilling the system because it is low just need to cycle compressor on. Not sure where to look now.
