What location, I check box by peddles and they are goodFuse and or fusible link.
Fusible links are on starter stud, fuses under dash by driver pedalsWhat location, I check box by peddles and they are good
The other way around with a schematic and you cover more ground when trouble shooting. Start at furthest point and then half wayA volt meter is your friend. Start at the battery and work your way to the starter and beyond.
If the battery isn't showing power starting elsewhere won't tell you anything.The other way around with a schematic and you cover more ground when trouble shooting. Start at furthest point and then half way
Was never specified Batt was deadIf the battery isn't showing power starting elsewhere won't tell you anything.
