converted customer car over from dfi to brand new stock wiring harness and ecm.no check engine light present,ground present at injectors no 12 volts,and no fuel pump.the pink and black wire to the ecm does not have voltage and there is no fuse in the panel for injector ive or fuel pump.both ecm fuses are good and a few terminals have voltage at the ecm with it unplugged.spray fuel in she fires up ,ignition system fires coil and plugs.12 volts to the fuel pump test port fires the pump up.relay doesnt click with key on.there is a positive power supply missing in the form of a fused circuit to key on run or an eec relay.anyone know where the fuse is?i will also check tomorrow to see if any sensors have voltage so we know the ecm isnt completely dead.the wiring schematics i have are crappy and the guy in illinois who built this for the customer was a filthy wirer.any help is appreciated.
