Has anyone ever experienced a noisy oil pump? Just did a complete rebuild using a Sealed Power Hi Volume oil pump- motor runs great with good oil pressure, 20-25 at idle. The problem is that when first started there is a rapping noise coming from the front cover area, which quiets somewhat as the car warms up. Replaced the cam sensor, no change. The lifters and valves are quiet. I noticed a little lumpiness when first turning the pump drive by hand to lube the engine, but didn't notice it when priming by the drill. Any thoughts?
Thanks, Dave
Thanks, Dave
