I've searched this topic and found some good info...but wanted to ask anyways. I got oil coming out of my valve cover breathers (mainly on the driver side)...enough that it's running down into the #5 spark plug hole. I just put on Champion VC's and K&N breathers and it got worse..mainly cuz these breathers aren't angled.
From what I've read, I tested the stock PCV (which seems ok) but it had a check valve in-line that seems to fail the "blow/suck" test. I'm going to replace both just to be safe.
Thinking about buying the RJC PCV to put in line with a stock replacement and some of their angled breathers.
Other than this, the car runs and idles great...if anyone has any suggestions or comments I'd love to hear them...still learning this car and don't want to be running any high crankcase pressure.
I'm running 26#'s of boost...but the oil is coming out even if it doesn't get into boost.
There is no signs of milkshake in the oil or excessive smoke.
