oil is on the oil pan bolts on right side only. also on oil filter. drips onto the cross over pipe.not leaking from valve cover or head. oil return and feed are dry also. took down the inspection cover to see if the main was leaking. light residue on back of the motor but not like ive seen with mains in the past any input would help thanks
