I have a problem... Maybe someone can help me out.
My oil pressure switch connector PLUG, having had oil drip on it for years, finally deteriorated to the point of "Is that a connector or just a blob of sludge?" About the same time, the oil light just stayed lit all the time.
So, I added an oil pressure gauge. Not wanting to lose the warning light, I added a tee fitting to retain the switch and add the new sensor. I picked up a new connector, wired it up to what I thought was correct (It was in pieces) and started the car to test it all out. Runs great 75-psi cold/15 psi hot idle.
So, the oil gauge works, but now the light does not (Ign on/car off).
I checked the bulb by swapping it with the BATT/Alt lamp (Car off). It works fine.
I verified the wiring to the sketch I made. All seems correct... But the wires are so old, the colors are hard to see... The replacement connector has all white wires... no help there.
Does anyone know what these 3 wires are for? I know 1 must be the ground for the lamp circuit... What are the other 2 for? Can anyone tell me what the pinout is?
(I know... I need a Service Manual!)
Thanks!
Thanks!
