inkcushion
I need parts to go fast
- Jan 23, 2003
I need some help! I was on the dyno the other day and my car started to smoke out of the breathers?So I shut it down> I went for a second pull,Iwas running fine and then all the sudden oil blew out of my breathers and all over my dp,started a little fire,it went right out so no big deal, car didn't loose oil pressure,wasn't running to hot, so we pulled it off the dyno let the car sit for awhile to cool down,started it up and it started to smoke out the breathers again we nursed the car home and I tore it apart,when I got the heads off had a blown head gasket on the drivers side,not in a water jacket. So my ? is is there any thing else that could be wrong like a cracked ring,and if this happened would it have messed up the cylinder walls,because there was no visable damageto the walls????? I need some help this is my daily driver so i WOULD LIKE TO GET IT BACK TOGETHER as soon as poss. , but I aslo don't want to have to take it back aPART AGAIN!!!!!!
