Oil Pressure, Coolant Temp, etc.. Where do they go?
SS/GNX
Formerly NothinYet
Hard to write a good heading for this, and I feel stupid for asking, but...
I have mechanical guages for Oil Pressure, Coolant Temp, Boost, etc.
Anybody tell me or show me pics of where the gauges plug into on the engine? Where is the hole for the coolant probe?
Where is the little fitting to screw on the oil line for the Oil Pressure gauge?
Where do I mount the boost gauge sensor to?
Any other ones you can think of or have pictures of will help. Starting from scratch and never had a GN motor before.
Ain't nothing stupid about your questions- stoopid is a REALLY BIG wing on a front wheel drive car........
Oil pressure- tap into the brass block at the PS front of the engine.
Water temp- I believe you can use the hi/lo speed switch on the top DS of the manifold.
Boost- tap into the MAP sensor on the PS innder fender.
Now- lemme see if I can find pics of all that stuff..........
Oil pressure top picture, water temp bottom picture.
Alright, I think I see where coolant and oil goes, Nice.
Not all that sure on boost though...
P.S. I agree about the spoiler on the FW drive car BTW... that is stupid.
Heres a picture of the MAP Sensor on the passenger side fender. The coolant temp sending unit is the brass fitting next to the upper radiator hose and clamp.
