87hottness
- Feb 17, 2011
Where is the factory sensor for the light on the dash ? I want to install a gauge and figured I would just pull the stock sensor and install the after market tjanks for tje help
It's much easier to work on with the rad hose off the block, you don't need to totally remove the whole rad hose.Ok thanks did you have to pull the rad hose off to get at it ?
Hi earlbrown, What does the fuel relay pump relay has to do with installing an oils pressure gauge sender?and if your fuel pump relay ever flakes out, you're fucked and waiting on a rollback.
The oil pressure sender has a switch in it that bypasses the fuel pump relay when the engine has oil pressure. I leave the stock sender in and put a "T" in for the oil pressure gauge.Hi earlbrown, What does the fuel relay pump relay has to do with installing an oils pressure gauge sender?
I'll try the channel locks if I have to but isn't there something that fits?
