Mr URL
- May 24, 2001
Having a freakin wierd oil pressure readings that is driving me nuts with my T-Type!!!
I installed a new VDO oil pressure gauge couple months ago. Before I took the motor out and tore it down to the short block to clean it all up with new gaskets, HV oil pump, timing chain, 206/206 cam, lifters, ported and polished heads, etc. it had 15 psi oil pressure at hot idle and 55 psi WOT stock. Cold was about 60-65 psi. It now has stock cover, HV oil pump with new oil pump gear plate, and 70 psi relief spring. New oil pickup tube gasket torqued to spec.
Now when cold the VDO gauge reads buried at 80 psi. Driving it a little bit after reaching full temp it's about 70-75 psi with a little rpm and 20 psi at idle. Give it some rpm (heavy throttle) after a bit warmed up or steady highway cruising it drops down to 40-50 psi with rpm and 17-20 idle. Pretty much stays at 40 psi with some rpm after a while.
Any ideas?? Gauge or sending unit? Can you have the oil cooler lines cocked wrong or any problems with installing the gear backing plate? Motor looked perfect inside and was tight (57K miles and had an easy life).
Humm...
Humm...
