I Got this amp out of my GS when i bought it and have had it forever. I just purchased a winter beater that has a Apine Head unit and a alpine CD in the trunk. This car had sub's in it also but where raped before i got to it.
There are two wires for right and left imput into an amp and also a power wire in the trunk for an amp. I assume an amp is an amp is an amp so i should be able to use this old amp to power a couple 10 inch sub's?..?..
If the amp had a place to plug some RCA input's in it would be a no brain...but of course it dosnt. The amp has a alpine plug and wire that i also assume was used to plug into the alpine head unit at the time.. and a bat wire and ign wire and also a ground wire. There is also a seperate plug on the amp that has 4 wires in it, they look to be 2 green and 2 gray wires.
Can i use this amp for subs?
Would the grey and green wires be used for input from the deck and then output to the subs??
I can send pics also if it'll help
Thanks for yor help..
