Would that be readily available for new or used heads?
How important is having it balanced? The car will probably end up being a daily driver for the most part but still see some action at the track.
I was also curious as to whether it was safe running a crank that will end up having been turned .020.
Why wouldn't you want to replace valve seats? I've never heard anything negative about replacing seats on these heads???????
I'd be more concerned about replacing valve guides!??? Are they planning on installing false guides or bronze thin-wall inserts? I'd opt for the inserts over false guides.
I also didn't see anything about the intake valves/guides or the valve job itself.
There are lots of very good materials available for seat replacement that are better than the cast iron integral seat.
My concern would be not so much the cost as much as how reputable the shop is and most importantly how experienced are they with turbobuicks, not only the rebuild, but getting them to run right and tuned when completed. I know a lot of good reputable shops that I would not let anywhere near my turbobuick at rebuild time. Actually at any time. HTH & good luck with the build.
I've never had a GN motor rebuilt before so I'm not sure if it sounded reasonable or not.
Please freel free to chime in with any and all opinions.
Thanks,
Christopher
Also make sure they use the Buick engine specs, NOT the small block Chevy specs. These engines run tighter clearances than the Chevy’s.
Agree with Fred 1000%!!!!!! Research the clearances yourself and DEMAND that that's what they shoot for. If they try to tell you that the Buick specs are too tight, go somewhere else.
Oh yeah, how many engines have you lost due to too loose bearing clearance?![]()
