- May 27, 2001
No problem......
and yes we can machine them down.
Jose,
Check your PMs please!!!
No problem......
Jose,
So an 80mm S400 variant with a T4 housing would be more than capable of 1100 HP @ 28 -30 psi efficiently?
Go with the biggest exhaust a/r you can get and spray the hell out of it on the line. Id bet that would give you a few mph.How about 224 ci?
Mine ran 9.20 at 151.99 at 30#s of boost and it spooled awesome
I ran 35#s nut it showed no gain over 30 on my setup
The EX a/r was a 1.10 if i remember correctly
Also the car weighed 3580#s on that run.
It also took a real good convertor to get it there
It ran a best of 9.46 at 147.11 with my Art Carr
I installed a PTC convertor Dusty and Chris brought with them(Billy T's convertor)Thanks Billy!) and it went right out to run
the 9.20 at 151.99,This was with a 60 foot of only 1.49
IMO turbo works great,The GT4276 will probably run just as good
Im not sure of anyone running their car at the weight I did that has the 4276
JZ, What would your recommendation be for the turbine housing as far as A/R goes for a person who is injecting a large amount of nitrous to assist spooling (turned off at 16 psi) compared to a setup that is not?Yes we could build one on a T4 chassis that would spool quick and make those #'s.
How would a GT42 76 or 76GTS compare? I'm thinking about switching from my current 72R. Thanks in advance.
Also, would there also be another A/R choice for a person deciding to use the nitrous injection for the complete 1/4 mile run?
Have you had any past experience doing setups where nitrous injection was used? Stories to share?
Thanks for your input. It is greatly appreciated.
Thanks Jose and John.
John, I thought you may know a thing or two about the car.
I just spoke to Jose and he said he could put something together for
us for ~$1000 and going to 1700 for a full custom unit.
The wheels that could be built out first are the 57,
62, 66 and 70.
57MM Flows 62lbs x 10.86 = ~673HP Theoretical MAX Potential ~ 620HP Conservative
62MM Flows 73lbs x 10.86 = ~792HP Theoretical MAX Potential ~ 730HP Conservative
66MM Flows 80lbs x 10.86 = ~868HP Theoretical MAX Potential ~ 800HP Conservative
70MM Flows 92lbs x 10.86 = ~999HP Theoretical MAX Potential ~ 920HP Conservative
It is always interesting to have other options...
