malibudave1978
- Apr 3, 2005
Double post.
If your running vacuum boosted brakes, it will be really hard to get around a fix for that if your engine doesn't make any vacuum. If you move your vacuum push rod up, you most likely will run into damaging the booster. The rod will most likely not be able to angle up that far.
Because your calipers have a smaller piston area, you can step down in bore size of your master cylinder from the 24mm to the 7/8" bore. This will help, but the new 7/8" bore master cylinders are about $70 and the rebuilt ones may be unreliable. All stock g-body 7/8" bore master cylinders are cast iron. The rebuilt ones are fairly cheap at around $25 bucks at Rockauto.com, so you may be able to roll the dice. DO NOT buy dealer closeout master cylinders from rockauto.com. You are asking for headaches.
Other things to do is change out your old rubber brake lines to new rubber lines or stainless steel flexible lines. Old lines will balloon with age reducing braking performance.
Look at different front brake pads that give a better cold bite. Semi metallic and ceramic pads require some heat to start working effectively. You want a pad that works well cold. 100% organics have these properties (Oreillys has them), but they will dust more and will not last as long. I am looking at running Wagner Thermoquiet pads to try soon. I just haven't had the time to test them, yet. The Wagner Thermoquiet shoes that I have on the back of my El Camino work very well.
After contacting them, these aftermarket brake pad manufacturers recommend these pads:
EBC recommends the Greenstuff pads
Porterfield recommends the R4-S pads
Hawk recommends the Street/Race pads
Lastly, if you are running the stock booster, you might try doing the larger dual diaphram B-body booster conversion. I am not familiar with this conversion, but it should help out even if your booster is getting some vacuum.
like I said I have been following your posts for a while. And I already did the Stainless brake line upgrade along with some Hawk pads. I thought about going with the 7/8" bore master tho. I was a little concerned about it being a direct swap. Won't the booster rod need to be lengthened?
My car came with the double 9" brake booster I do have the info needed to help me with the Dual 12" ,B-body, booster swap. I got that info from the montecarlo site. Remember I tried an auxillary vacuum source. And although It did supply a bunch more vacuum it made no benefit in the front brake clamping. Surprised you havent said I need MORE horsepower.lol . The motor I'm running is not lacking power so thats not the answer .Dave if you feel better about sending me a PM about a 7/8 master that will possibly work please do.
Another option is checking into a new brake bias adjuster. ( whatever its called)
the Hawk pads I used were the Hawk HPS in a blue box. I think carbon/ferro material? But I did bead them as per hawk instructions. I've never went through a beading process before these, but since I paid like 50bucks for these pads i wanted them to be right. I have no complaints with my braking system expect I cant do a proper burn out. The tires spin like heck but the car moves. I really need to get some footage so I can really see what is going on.I don't mind hashing this out here. It might help someone else down the road.
The 7/8" bore master cylinder is a direct bolt in. Other than the bore size, it is the same casting as the cast iron 24mm, power boosted master cylinder. The 7/8" bore master cylinder doesn't have a retention cup built into the master cylinder like some other master cylinders. The factory used a retention cup to hold the pushrod up against the master cylinder piston. If you buy from the auto parts store, measure the bore before you buy just to make sure it is no larger than 7/8". Sometimes they will sell a 24mm bore master cylinder advertised as a manual brake master cylinder with a 7/8" bore.
Which Hawk pads are you running? I haven't tried the Hawk pads out yet and I really don't know how much heat they need to work best. It might be good to try the cheap organics from O'Reillys if you have one near you. Like JAM said above, the Wagner Thermoquiets might be worth a try also. They are fairly cheap too. A pad change would be the easiest mod to try first, so you don't have to bleed the lines out after you install the master cylinder.
You also might want to look at the Hawk pads to see if they aren't glazed over from an incomplete bedding process.
Keep us up on what you find out.
As far as the 7/8 master do you have a suggested retailer? or do you have one on your site?
Yes the hawk pads may need some heat... I'm not sure how a "street" pad works, but I suspect it doesnt require a little heat to start grabbing to its highest CoF.
