Intercooled88s
Moderator
- Aug 10, 2004
PM sent
Got the Paypal. I'll get those shipped to you.
PM sent
84 T-type clone
Air dams and scan master are sold other wise everything else is still for sale.
How much for a battery hold down bracket for a GN?
Its a 79 Lesabre sport coupe, looks just like a T-type wheel. I reaalyneed both pieces though? How much for an aftermarket boost gauge?
Needed, brake pedal assembly for vacuum conversion, pm me or respond to this let me know if you have one .
I found your info. Are we still doing this transaction?I will pm my info.
For just the boost gauge $30 shipping included.
I saw your looking for a ratchet shifter. I have a few after market shifters for both 200 4r's and turbo 350.
huge rear sway bar,pui seat covers...still available?-All prices do not include shipping, unless stated.
-Brand NEW still in the plastic 85-87 GN Front PUI bucket seat covers(drivers and passengers seat, upper and lower) $300 picked up
-New tranmission shifter cable(after market) $18
-Huge rear sway bar $75
-Hot Air(84-85) conversion kit to Intercooled(86-87) $1800 Includes almost all the stock 87 parts needed to convert over to intercooled, E mail for parts list
-7.5 posi rear end 3.73 gears complete drum to drum $350
-109 turbo block std bore $300
-Good std/std turbo crank $300
-8.5 Posi unit from a 87 GN $225
-86-87 Engine wire harness(no injector harness) $200
-86-87 Intake manifold(lower and dog house) thats been painted $160
-84/85 GN front air dam $50
- 87 turbo short block std bore $800
-New after market cruise control shifter lever $30
- Dutt style drive shaft loop $20
-Dash plaque for a GN in driver condition $40
-86-87 stock turbo, very little play $200
-84-85 stock trubo, very little play $100
- 84 GN front and rear seats(leather and cloth) need to be recovered $200
-86-87 T-type rims(no center caps) $300 for 4 or 1 for $100
-BRF 200 4r $500
-NOS Turbo 6 emblem $50 Free shipping
-Autometer Boost gauge with A pillar single pod $25
-86-87 original MAF(not Rem.) $90
-86-87 AC compressor $75
-86-87 Belt tensioner $75
-87 Intake manifold(lower intake and upper dog house, with metal waterlines) $200
-8445 heads Rebuilt with around 20k on them $100
-87 Engine harness with inj harness $230
-Turbo shield $30
-Rad hold down plate $30
-Front license plate bracket $20
-86-87 Air dams with some imperfections you cant see when on the car $35 for both
-Doors $400 for set(1 pass and 1 drivers) they are manual windows and manual locks have just the start of surface rust on under side. Pick up only, I wont ship these.
-Vac brake set up $100+shipping(master cylinder, power brake booster, and correct pedal)
-87 442 Passenger side New rear quarter -Make Offer
-gray 87 442 bucket seats $200
-locking T-tops $200 a set
-84-87 Regal/T-type header panel(has hole for emblem) with good black paint $200
-84-87 Nice Header panel (Hole for emblem has been filled) $200
-GN driveshaft $75
-Stock 109 Turbo long block(120k) $1100
-87 GN 109 short block, .040 Cast pistons, .010/.010 turbo crank, never run $800
-86 NA 3.8 Engine complete runs good has 109 block $350
-84 NA 3.8 Engine complete runs good 290 block $250
-84 turbo Regal block .030 over $150
-85 Turbo Regal Block .030 over $150
-109 turbo block .030 over $150
-109 turbo block .060 over $100
-Turbo crank(Std/Std but will need to be turned at most .010/.010) $250
-Under drive crank pulley and alt pulley $40
-15" ARE 398 rims(GNX style) $350 for set of 4
-15" Kirban style GNX stlye rims $350 for set of 4
-16" Western wheels GNX style rims $350 for set of 4
-86-87 T-type center caps(Tri shield) $40 Each
-86-87 T-type wheels(set of 4) no center caps $300
-85-87 GN steering wheel $100 no horn ring/center
-84/85 Turbo has some up and down play but works normally $100
-Nice set of GN tail lights with blackout trim $160
-84-86 GN Power seat track assembly $150
-Floor brackets for console $30
-Regal doors(They have very little surface rust on under side) $150 picked up only
-Floor pan for bucket seat car $150 picked up only
-Rear quarter $150 each picked up only
-Rear frame rails $100 each
-Front frame rails $100 each
-Control arms(Front lower)$60
-Control arms(Front upper)$30
-Motor mounts(metal, frame mounts) $35
-Turbo crank(.010/.010) in nice condition $200
-NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35
-84-85 Flex cooling fan $10
-85 Power steering pump(For car with power master) $30
- trans cooler $20
-B body spindles $50 for pair
-85 Maroon bucket seats $200 good condition
-85 Gray bucket seats $200 good condition
-Maroon shifter handle $25
-Blue shifter handle $25
-Crank window regulators $50 for both doors
-Dash vents(with nice chrome) $20 each
-Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both
-Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75
-Visors good for cores(non mirror) $20 a set
-Chrome marker light $35 each
-Both front head light bezels(need to be painted) $70 for both
-Rear center filler(The part that the rear license plate bracket attaches to) $30
-Pass remote mirror bracket(Just the bracket that attaches to the dash) $15
-NOS black plastic seat track cover for rear right side(GM part # 20023766) $20
-Frame in good condition $200
-heater box shield $15
-84-85 Shield to cover heat hoses $15
-bumperette rubber strips in good condition(used GM not after market) $20 each
-Stock factory lighter $8
-Stock Battery hold down $10
-Connecting Front Brace $25
-Front frame braces(underside) $25
-Plastic Brackets to mount front air dam $30 for 2(For both sides)
-Good hood shocks $10
-Stock turbo inlet bell $20
-86-87 engine hoist bracket(on intake) $20
-New Felpro Valve cover gaskets(Perma Felpro) VS50156T $10
-87 gray cloth Limited front and rear seats $200
-87 gray column (shift on column) $100
-87 Split bench seat power seat track assembly $100
-Original GN Quarter extensions for car with spoiler $40
-84 Red upper door panels $80 minus chrome/gray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
-Drivers side Blackout head light bezel $40
-Chrome head light bezels painted black $40 for both
-Black trim Marker lights $40 each
-Blackout wheel well moldings $60 each
-Chrome(Regal) wheel well trim moldings $45 each
-84-87 T-type header panel with hole filled $150
-84-87 T-type GM header panel, has some small imperfections $125
-84-87 Grand National GM header panel, has imperfections $125
-Passenger remote mirror(needs paint) $60
-87 GN seat belt set(10 pieces) $120
-84 GN steering column with tilt/cruise $150
-Maroon steering column with tilt/cruise $150
-87 GN grey column with tilt/cruise $150
-87 grey column(shifter on the column) $100
-84 Blue column(shifter on column) $100
-84 tan bucket seats $250 with rear seats $300
-86 blue 86 442 bucket seats $200
-85 Gray 442 bucket seats $200
-Gray Monte SS bucket seats $200
-85-87 Gray concert sound lower door panels $100
-GN Dash Plaque $75
-84-86 T-type dash plaque $50
-86-87 Upper intake(dog house) $30
-86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
-86-87 bare throttlebody $40
-86-87 Up pipe $25
-86-87 Cruise control assembly $40
-86-87 Water pump pulley $25
-86-87 Main accessory bracket $70
-86-87 Y bracket on back of Alt $35
-86-87 Flat Y bracket on front of AC compressor $35
-86-87 Intercooler brackets $25 each
-86-87 Coil bracket ( The horse shoe shaped bracket) $30
-86-87 Power steering res. bracket $20
-86-87 Power steering pump $70
-87 GN Electric fan $50
-84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
-86-87 T-type wheels $100 each
-87 locking t-tops $250 a set
-84-85 Non key locking t-tops $150 a set
-Astro roof complete assembly with wire harness, switch etc. $200 wont ship
-Bigger then stock front sway bar $70
-Fuel sender/fuel hanger(analog gauge) $60
-BQ tranny $250
-Rebuilt BQ tranny $400
-D-5 convert $50
-87 chrome grill painted black(looks good) $100
Looking for a pair of maroon pull door handles and a maroon t shifter handle.
looking for 2--door pulls-gray--shipped to 60548--thanks Bob
