nailheadpowered
- Oct 31, 2004
86/87 long block engine complete with flywheel and timing cover with cam sensor and oil pan. stock bore and crank etc. 750.00
pt-72 turbo with p-trim housing needs a rebuild 500.00
gn rear bumper with aluminum support, bumper has small dent below rubber strip 75.00
complete a/c box with lines condesor etc. everything to replace you setup if it was removed. 200.00
modded ecm for low and high imp. inj. ecm was used briefly with 83lb inj. 175.00
ecm chip for 83lb inj w/alky 50.00
more to come you can contact me directly at nailheadpoweredgs@sbcglobal.net
