The following parts were just replaced:
Radiator
Oil Cooler Hoses
160d Thermostat
Water Pump
Water Heater Valve
Belts & Hoses
Power Master Brake (Reman)
Front Calipers
Coil Pack
Plugs & Wires
Valve cover gaskets
Fuel Filter
Oil Change
Transmission fluid/filter change
Brakes bled
Differential fluid changed
Before the change, the car ran smooth, except for the brakes, which had a delayed reaction, and some smoke from the valve cover gaskets.
Now, the car runs a little rough at start up, and also has white smoke at start up. Also in the higher gears, the car feels like it has very little power, unless I accelerate a fast pace.
If I accelerate at a fast pace, the check engine light comes on
If I accelearate at a slow pace, the check engine light does not come on.
I diagnosed the check engine light, and it reads, 3 flashes, pause 1 flash (3 pause 1), no idea what it translates to.
I am confused, could somebody help.
The good news out of this, the original problems are fixed.
Radiator
Oil Cooler Hoses
160d Thermostat
Water Pump
Water Heater Valve
Belts & Hoses
Front Calipers
Coil Pack
Plugs & Wires
Valve cover gaskets
Fuel Filter
Oil Change
Brakes bled
