One day my passenger power window stopped going down. I assumed the motor was just wore out so I ordered a replacement. I took the door panel off and started figuring out how I should remove it when I figured I would test the switch. I can hear a clicking to go up but nothing to go down. I pulled the plug from the motor and attached it to the new motor on the ground and it will only spin one direction. Has anyone ever experienced this? The issue is the same from both driver and passenger switches.
