Improperly managing bottle pressure. How's that?
I lost you on the tuning somewhere. If you have any questions, I'm happy to make it clear to you. Please, let's discuss the 'other things'.
You can dial in more of the fuel table with a low stall TC, than with a high stall TC. Take my word for it.
If you go straight to a high stall TC, you will miss the opportunity to tune in much of the low to mid rpm, high map region. If you're racing with a high stall, and all that is needed is WOT performance, then you won't need to dial in that region of the fuel map anyway. It would be a waste of time. But,... the fuel map will be sloppy. Tuning in a fuel table with a high stall TC, and consideration only for WOT use is a cake walk.
If you dial in the fuel map with a low stall TC, switching to a high stall is a breeze. It took me one pass to find 2 or 3 cells that needed 1 and 2 percent correction. Fuel table is DONE!
As I've already stated, I've talked with 3 TC professionals throughout this project, including Dusty awhile back, and they all had the same reaction.
