HOTSIX said:The pic that you have of the vac block (top of the throttle body) with what you thot was a 'tee'd' into vac line is actually the vac line that has to travel from the vac block to 1 of 2 spots - 1) the MAP sensor mounted on the Pass side fender 2) the HVAC (your heater controls) / Cruise - although it looks as though your cruise cable is done....
If you dont have a vac hose map on the fan shroud - let me know - I can take a pic of mine or there shud be here or on gnttype.org.
Well, front what i saw with that vac line, it looks like it went to a longer thing on the pass side, which i think is my hvac, and then over to my cruise. thats it. As to that cable there, is that suppose to go to my cruise? its a speedo cable looks like, when i pulled it out, the end was squared off like it sat into something, and then the end showing is all jagged like its been just or something.
