EyesofThunder
- Jul 3, 2008
My 00 PAU is having a fair amount of KR, running 93 octane only (GM designs for 91), and I still get a fair amount that I can't seem to tune out, and even teh STONE STOCK tune has upwards 9 degrees KR, I don't think it did when I got it a few months ago. I have tried and tried, so I am thinking there must be something else at work. It is almost ALWAYS at the moment I enter PE mode.
I have replaced plug wires and 2 of the 3 coils when I got it.
I have gutted air box.
I have tried 160 stat, no help, went back to 195.
I am seeing it with intake air around 60F, so not hot out there, when hotter out, still seeing it around the same.
I have varied stations I get fuel from, typically I have a Shell I go to. But Mobil, Road Ranger, Walmart and Citgo (I typically avoid) still have the same problem, even in different regions.
I have used 10% ethanol and non, no change.
I have bumped up the VE tables too so that the transition time sees more fuel, no help.
Are we even getting 93 octane anymore? How do you check? I am ready to get me 5 gallons of race gas to try.
I am ready to go to E85 again and see what it does. I ran it before and I did see some KR, but not as much, but I want to see if now on stock tune if KR will go away with the current tune (stock) and conditions.
I did turn off EGR and it seemed a little better, (5 degrees instead of 9-10 KR) but that isn't the answer.
It is always in the same region. cyl air 500 mg/cyl to 600. And 2400-3800 rpm seem to be the most touchy range. Dropping timing below stock, no help. Adding fuel doesn't help either. Changing the point we enter PE mode seems vary it a small amount, but again, not the answer.
Thoughts? What is common on the 3800 SC that might cause pinging? Engine is 87K miles, 11K in the last 90 days, so it sees fair amount of miles. Plugs are stock, so I was planning on swapping them out to some NGK TR5's to see if that will help. 87K on stock platinums bad idea? The friend of mine who races a lo 10 sec Small Block Olds 67 Cutlass says to ditch platinums without question.
Edit: I attached a short datalog. I cannot get the Knock Counts PID to read at all. Not once. Does it even work? EFILive and MXScan both can't read it.
