DFAST1TTYPE
"owner atomic launch car"
- Jun 30, 2003
For a couple of years now I have been trying to get Orlando Speed World, the host of the World Street Finals, to make changes to their “HEAVY STREET” Class in order for some of the Fast V6 Turbo Regals be able to run this class and be somewhat competitive.
Current rules are as follows:
· Any tire - 3,500 lb. minimum - (Must use converter driven trans - 1 type power adder)
· Stock chassis or any chassis with a-arm front suspension OK.
· Struts must be stock type, originally available on the car and used with the stock front frame rails or a direct bolt in conversion with stock front frame rails.
· Additional tubing OK.
· 4/10ths Pro Tree
I am asking them to amend as follows: "deduct 300 lbs. for V6 with turbos". They do have weight adjustments in other classes, however, not for V6 with turbos.
I am asking board viewers and members if they could please E-Mail the track at: OSWD1320@aol.com. with the same request, the more the best. Maybe if they see a lot of E-Mails they might just change the rules so some of us with fast Buicks can run.
Last year the bubble on this class was 8.72 @ 156 and the low qualifier was 7.72 @ 182. In my particular case I probably would not win however, I could probably qualify in the upper half of the ladder. There are however, other fast Buicks that if they show up might have a chance. I will race if they change the rules. Just for the sake of competing.
The tracks web site is: www.speedworlddragway.com in case you want to read more about the event if you are not familiar with it. You can aslo link to their E-Mail from their site.
All your help is appreciated.
Thanks.
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
· 4/10ths Pro Tree
Thanks.
