Yes it was a new pump.
I ordered a new diaphram for my acufab today and also a voltage booster from capers. I am going to check the connections at the fuel pump and also cut the ground wire at the fuel tank and run a ground all the way to front of the car.
Hopefully this will correct what ever happened in that first run with fuel.
Do you guys feel that this might be affecting injector duty cycle. I woud think 60's should be fine at my horsepower level.
