PLS help no dash lights
WIZZARD6
Hello need help dash lights not working,I changed the fuse and it poped again hour later so I replaced it again and now i have no power to the fuse then I replaced headlight switch and dimmer switch and gues what still no dash lights and no power to the fuse Can someone pls help me
No power to either side of the fuse?
When the fuse block is missing power I would start checking stuff like breakers and fusible links off the starter.
Do some checking on the GN T Type org - bet they have a diagram
Thanks will check fuselinks breakers and look for wire diagram. Will post findings later.
Checked tail lamp its good all lights headlights flashers tail brake lts all good, at this point a pinlight will have to do. Thanks for your replies for now GN 1 OWNER 0
