Plug Gap
trbojo
'Stang Stinger
Built long block, low 10 capable. 28-30 psi, pump gas and alky. Basically stock ignition with msd dis 4. Using autolite 103 plugs. Who's running what gap and recommendation...
Sent from my XT1254 using Tapatalk
.022"-.025". Wouldn't run any more regardless of ignition type. If its stock coil pack and module, keep it towards the low side of .022" to maybe even .020".
AG.
Honestly if ur running that much boost I would opt for race gas or e85. I don't like playing with fire.
But anyways
I run ur5 at gapped at .020 but we run 30-35lbs with the MSD 8.5mm wires never misses a beat
low 20s like others suggested.the 103 plug works good
Keeping it safe at 23 pounds of boost, I am at .028 so far I logs look fine.
543 HP 704 FT pds
XFI with factory ignition.
