HelloBozos
A Bozo in Buick
- Feb 9, 2011
Hello,
My names Brent but go by Bozo on-line. I like to start this simple,easy reading post so a visual pattern emerges over time. I can't do a pole for single person/multiple failures or i would. I'll go first...(i hope to be on my latest build for long time,Knocking on Wood!) Like the post to only include Turbo Buick V6 motors.
Please keep it basic the : Failure / Type of Motor / Mileage / Year / Car
Rod bearing / Factory warrantie stock 109 / 113,000m / 1990 / 86GN
Other Rod bearing / Factory warrantie stock 109 / 113,200m / 1990 / 86GN
*** 86GN got totaled (i wasn't driving) bought 87GN- 67,000 miles ***
Camshaft Lobe / SP Cam swap fresh rebuild 109 / 500m / 1992 / 87GN
Camshaft Lobe / SP Cam swap fresh (again) rebuild 109 / 1500m / 1993 / 87GN
*** Stored the car an built 73 Camero ***
Camshaft Lobes / SP Cam Fresh John at BGC build 109 / 1000m / 2004 / 87GN
Head Gasket / KDK Orlando fresh roller cam build 109 / 800m / 2005 / 87GN
Head Gasket / KDK Orlando fresh roller cam build 109 / 500m / 2006 / 87GN
Dropped Valve / KDK Orlando fresh beehive champ head build 109 / 500m / 2007 / 87GN
On the Dyno Head Gasket / KDK motor rebuild at Lamotta's Perf 109 / 30m / 2008 / 87GN
On the Dyno Piston Pin / Lamotta's Perf. fresh rebuild 109 / 0m / 2009 / 87GN
Cracked Block-Sleeve / Heartbeat Racing fresh stroker rebuild 109 / 1600m / 2010 / 87GN
AN now..
So far so Good / Central FL Speed an Machine Virgin Block stroker rebuild 109 / 20m / 2012 / 87GN
No need to mention my patterned Lead Foot. In all these motor build's i've found it comes down to the Machinist over the Tuner....True,A Tuner can ruin Fresh build, but if the build's not to Spec before hand, the inevitable Will Happen...Motor reliability comes down to Proper Machine Work, Proper Tune,an Proper usage.
I think i have the first two covered now, the Last part, Not so Much as i like Speed....8^)
AN now..
