I am going to pull the rearend and put an Eaton posi and Moser axles in over the winter. Stock unit and axles are good but I have a fresh motor and transmission in it, so I figured I would replace the posi before it is the weak link in the chain. Question is; should I replace the upper and lower control arm bushing with poly urethane while I am there (either Prothane or Energy Suspension). Will this be advantageous? Mine are original with ~90,000 miles. 60ft. is usually around 1.65-1.7. I plan on boxing the LCA's too since they are out, but is poly the way to go or will new Moog bushings suffice. Just wanting to know what works. Thanks
