Would be great if Jason could post here and settle it, for all future users who search this subject tooGood question.
I'll leave it up to to Jason, who you should just call and ask, but I'm thinking after the spacer and at the plenum.......
Good luck in your quest.
I get that. Not a lot of vendors are on here anymore or post here.Would be great if Jason could post here and settle it, for all future users who search this subject too
Yes, spacer first on intake, then plate then plenum.
This is my guess as well if I'm reading it right. Plate would go on top of intake, then spacer, then plenum. Thinking the higher the plate is from the intake the more chance air would mix and counter act the plates purpose. I would think youd want to use the plate to separate the air right before going into the intake to maximize proper air separation.I don't think that's right, but I could be wrong.
I'm thinking, going from Intercooler up pipe, Plenum, spacer, then plate. maybe we are seeing the same, only different?
It will interesting to see the answer from Jason.
I guess that solves that issue, thank you for posting!Jason just replied to plate position, "plate on top of spacer"
Thanks to all that replied.
