Possible mods for '84 Hot Air car in Cali (San Diego)
Discussion in 'Smog tech and emissions tech' started by John Knolla, Jan 1, 2017.
  1. John Knolla
    John Knolla
    Expand Collapse
    Dec 24, 2016
    10
    0
    Offline
    Title says it all, what performance mods are possible under BAR and Cali smog? I'd like to be able make as much reliable HP as possible and pass smog so I dont have to go through hassle lf registering it another state.
    Car is bone stock, 1984, ~103K miles.
    Advice appreciated.
    JK
    Edited to add, question is stuff like 3" down pipe, alky, '87 ECM/MAF swap, larger turbo, etc. - what does experience say a person can get away with in the nanny state?
    #1 John Knolla, Jan 1, 2017
    • Winner Winner x 1
  2. NorCalTurbos
    NorCalTurbos
    Expand Collapse
    Not a V Ate
    Nov 9, 2013
    1,017
    31
    Offline
    I recently passed in Northern California with the cold air kit open k&n filter, adjustable fpr. But for some reason I had to put the sto ecm back in for it to pass. To each his own you know how finicky Kali is when it comes to smog shops and the things you are asking about could definitely red flag the tech as far as the visual goes 3" in California definite fail when it comes to the visual inspection. Most exhaust shops don't even have the 3" bender because it's illegal for street use in CA. I usually make friends with a few shops techs in town by sending them business and whatever else I can do to get on their good side :cigar::cigar::D and as long as the car runs clean, the cat is on and no codes they pass it if not, you pay :greedy: you pass :whistle:
  3. placestovisit
    placestovisit
    Expand Collapse
    Mar 17, 2017
    2
    0
    Offline
    These industrial technologies are very good for environment
  4. 1986 Buick GX1
    1986 Buick GX1
    Expand Collapse
    GX1 #001 [The One and Only]
    Apr 24, 2015
    673
    60
    Offline
    Would they fail you for running E85? Do they check for a stock chip?
    It seems that a good 2 1/2" dual exhaust with a high flow cat running E85 on higher boost would perform well and pass emissions.
    Is it possible to run a cold air intake on it if you paint it factory black?, and use a shield/ cover over the air filter to make it look stock?, or hide it altogether?
    Is it possible to talk to the techs to see what "replacement" parts are allowed?
    Just a curious Idiot Out Wandering Around. (Iowegian)
Share This Page
