G gnx017 Member Joined Feb 28, 2003 Mar 16, 2007 #1 Greetings; Has anyone had problems with the power antenna? The antenna is getting stuck 3/4 of the way down, at that point the motor keeps running. I have lubricated lightly, no effect. Thanks,
garyk1970 Electronics Moderator Staff member Joined Nov 4, 2005 Mar 16, 2007 #2 sounds like the internal nylon cable is broken.make sure the masts are clean and not bent any.
G Grumpy Thread killer Joined May 24, 2001 Mar 16, 2007 #3 I think its the most common problem with these cars prob from sitting to much
G gnx017 Member Joined Feb 28, 2003 Mar 16, 2007 #4 Thanks, someone had mentioned that in order to replace the motor, the fender has to be removed? I cannot believe the great minds of GM in the 80's could have engineered a fix that simple!
T TurboRegal84 Moderator Staff member Joined May 24, 2001 Mar 16, 2007 #5 Here is a link to a thread where this has been discussed in depth: http://www.turbobuick.com/forums/gnx-fortunate-547/198832-tried-remove-power-antenna.html
