BOJANGLES
Its alright.
- Dec 16, 2015
Any possible way to convert the suction side of the power steering pump to a AN fitting? Did searching and just getting lazy now. I’ll appreciate the input.
SignUp Now!If I'm reading this right, your talking about the power steering pump on the motor? If so, you can cut the neck down on the stem of the pump and braze a bung on there. That's what I did to convert my pump to AN. See link attached for fittings. Not sure of the size tho because I did it awhile ago.
https://www.racetronix.biz/storeitems.asp?cc=weld_bung_fit
Or you can use a Racetronix fitting with the olive that you can crush onto that stem if there is enough room. I used this on my Vintage Air heater to convert it to AN, and it works awesome.
You have photos of the vintage air??
Search Vintage Air under my user name. I made a detailed thread of my install.
That fitting you have circled is just pressed in. On my hybrid project, I simply pulled it out and tapped it 1/2" NPT. Easy Peasy
-10AN fitting and line for the PS supply (low pressure) and -6AN fitting and line for the output (high pressure)
Ok, I’ll get it figured out. Thanks for the input everyone. Greatly appreciated.
Let us know how it works out. I like to do the same.
anyone have a new pulley laying around? and or a suggestion on which one to use? not against going aftermarket or some type of shiny stuff. eventually ill do some measuring and buy a nicer one. next couple of weeks i should be putting this back together and doing a nice write up for everyone.
I have a good used pulley
