achalmersman
- May 28, 2012
I'm not saying your wrong I appreciate all input. But I put a lot of time in it today. I have always worked by the statistic that says if a problem didn't exist before, than something you did probably caused it. After several hours today of testing I am pretty confident that somehow the issue only happens when the I/O board is plugged into the power logger. It would never do it when that was unplugged. Plug that in and problem returns. Over and over. I started then taking inputs off the board tk determine if it was a sensor or just the board being connected that was causing the issue. I need just a little more time with the wideband disconnected to draw a conclusion. I'll keep you posted. If I have wastes my time and cannot find a pattern I will take a coil and or module off another TB I have. You might be right.
