Lil Truck
I spend to much time here....
- Sep 26, 2002
Great news to add to this thread !!
Last weekend I changed out the non resistor plugs to NGK resistor plugs and had time for a few short test runs that were successful !!
This morning I went out to my test road and made full through 3rd gear test passes, All worked perfectly !!!
Added info all the electronics i.e. Computer, chip, injectors, module, coil pack, power logger, several different resistor plug for iron heads and tablet have been in the car for the past 3 years without any problems.
This problem occurred after installing a new motor with TA Aluminium heads. I ordered the recommended NGK plugs from the TA web page. (I did not realize they were Non resistor plugs, nor did I know this could be the result of using them !) This problem probably does not happen if you are running an after-market computer.
Good lesson learned !! Thankfully it was just a set of spark plugs!
Thanks for everyone’s help!!!
