Hey guys I'm looking for the latest update for the logger I've been searching but haven't found anything on the latest where you can change parameters and whatnot..thanks for any info...Mike
I'm not sure exactly what version I have, I believe I purchased it around 2010 or so., but basically I'd like to have the ability to change parameters 1-4 through the laptop instead of the gas pedal trick..
Currently running a TT5.7 chip...Mike
but Eric will be able to tell you what version is required to adjust the parameters in the chip. The chip needs to support that operation along with the PL stuff.
I don't think so, ..I played around with a fellow members logger recently, and on his you could change parameters #1-4 via powerlogger... he also has a tt5.7 chip...I'm just trying to make fuel adjustments through logger/laptop rather than the gas pedal trick...Mike
