powermaster fuse keeps popping??
tpabayflyer
My 87 GN has popped the 30 amp fuse about 3 times in the last month... anybody know why?? TIA TBF
i would check the pressure switch first and im sure you know that they aint cheap.:mad: :D
Go to gnttype.org and follow the flow charts and several great articles written to help us out with our Powermaster brakes.
HTH
Jim
The powermaster electric motor is probably on its way out.
Mine started blowing fuses here and there, then not too
long after that, the electric motor seized up.
I know you can change just the motor if you want, instead
of replacing the whole powermaster.
These cars are no fun to stop when the motor quits:eek:
Mine did the same thing. When I started looking at it I realized that once the motor warmed up it was running for about 22 sec every time I hit the break :eek: Bought a new P/M from Kragen and I've been stopping great ever since.
Thanx alot guys... looks like the motor is on the way out.. I did replace the M/C about 10 years ago but the motor is original... can I buy just the motot itself?? thanx TBF
Look on the turbo trader at gnttype.org. I've seen ads for NEW motor assemblies from a guy that bought the tooling from the general.
Thanx.. I have read all that and I am going to convert to vacuum.. I am the original owner of this car and the brakes have been marginal at best.. I am on my 3rd accumulator ball... rebuilt M/C...etc...... I can convert to vaccum for less than the cost of a new motor using new stuff..... I am tired of the problems so I will solve it now and do it right.. If vacuum is good enough for the Turbo T/A's it's good enough for me.... TBF
thats the way to go. when you do , do yourself a favor and get the tta vacuum block.:D
Re: Re: powermaster fuse keeps popping??
YOU'LL HAVE FITS......... IF YOUR MOTOR QUITS! :p ;)
