I do not have pics, but have installed a few. It mounts using the stock bracket on the driver side, and a bracket they send with the cooler on the passenger side. You remove 2 waterpump housing bolts to install the other bracket.
I have noticed that it is a much easier install if you bolt it in but leave them a bit loose. Then after you have the hoses and clamps tight, do the final tightening on the bracket hardware. If you have front frame braces, you will need to spread them out a bit with an additional plate. I made a flat plate and bolted it to the underside crossmember, and then drilled 2 other holes and used nuts and bolts with washers to hold the bars to the plate.
The Cooler is a very nice piece and works great. It is BIG, but the install is not tough at all.
Hope this helps...
Coach
