X2 stop worrying, fire it up!I've primed a SBC by hand with a speed wrench. Squirted out out of the rockers, fired it up. Idk. I would fire it up
Cool man. Do you know someone at a machine shop?I've primed a SBC by hand with a speed wrench. Squirted out out of the rockers, fired it up. Idk. I would fire it up
I guess I'm considered the "assistant" around the machine shop. I have the privilege of working with a man who machines and engineers drivetrains that have propelled cars well into the history books in Bonneville and El Mirage.Cool man. Do you know someone at a machine shop?
Pick up leak.. Put about 2-3 extra qts in it, and try it.
Who installed the front cover? Did you check all the bolts? make sure they are all tight and one is not missing. There is one small bolt that is easily missed just above the oil pump. Second bolt up from the bottom.
I have seen a casting crack in the back of the engine mount bolt hole (almost not visible) which will leak into the pump output galley along the block skirt. This happened to me. I sealed the bolt and no further issue.It was installed at ATK along with the oil pump. I am going to add more oil tonight, make sure the pickup is covered at the gasket mating surface and prime it. Just completely rule that out. Then the front case and oil pump will come off.
