84' TurboRegal
Only a 6 cylinder?
- May 31, 2010
Thats what i had in mind, 2.25 seems like it would hold enough pressure to build boost
I fear your oil scavanging system isnt going to be enough and since you are using turbos with carbon seals there going to want to seep.
A.j.
How exactly are you going to run the exhaust, true duals? what are you gonna do about the passenger side header?
What do you suggest? At an idle it seems to work fine but that is at an idle and not up to temp. I actually wanted to do a dump tank below the turbos where the oil would just pass through the turbos and dump into the tank (same concept as in the stock location where the oil dumps directly back into the intake) and then scavange the tank. I didn't really have enough room for this without it being very noticable from behind the car. I could always go to larger drain tubes under the turbos and then scavange from them (same concept really). This is the main reason that I posted this as a project as apposed to waiting till it was a finished project, I wanted you guys to help me figure stuff like this out before I sunk a fortune into it and it turn out wrong....
exactly what your saying, a type of sump if you will... atleast thats what I think.
what are you using for a pump to remove the waste oil?
A.j.
