EclipseTurbo
- Jan 15, 2003
I've got the propain kit installed. The I left the reg alone running at natural pressure about 110-120 PSI. 81 Jet (middle). 50% duty.
I set it to come on at 7 PSI. Oops, I think it's too little boost and too much fuel. The car sputtered and hesistated badly. Just a note: my engine is only 2.0 litre and this maybe this is too much fuel. I tried around 30% duty and ran 11 PSI and it still stumbled.
I am still running 100 PSI distilled water injection however, maybe it reacts poorly with propane?
So I decided to turn off the Propane switch and dial in the boost controller to run 14 PSI first.
Shortly after the nozzle nut on my pipe felt off causing a huge boost leak.. and I limped it home. I knew I shouldn't have JB welded the nut onto the pipe. 110 PSI of propane shot the nut with the hose off ... So this time I bring out the welder and do it the right way.
I'm going to install the smallest jet and head out again.
Has anyone got their car to stumble before? And should I take out 5-10% of gasoline?
