Pronto
Believe nothing you hear and half of what you see.
- Dec 9, 2002
I guess the Snow kit you have uses the MAF signal not the MAP signal that the Alky Control kit uses. Your're going to have to probe the wires out of the Translator to find the 0-5v reference. Not sure if they even use that as a reference. Someone with more experience with MAF signal wire references will have to advise. I know the MAP signal works fine with Alky Control system though.It wasn't failing, I do know this for a fact. I am just wondering how the LS1 with translator behaves with MAF based injection. Is it going to spit fire out the filter?
BTW, the stock MAF is now extinct. Replacements in the parts stores are very much a gamble. Most will make the car run like crap. The stock design was restrictive and fragile. I'm glad you know for a fact the one you have is perfect.
