when i look at my runs on the street just tuning...i notice that the field for the
TCC
3rd
4th
P/N
they don't change....my TCC stays on all the time and my P/N...i've see the P/N turn off for a frame in the turbolink data but that's it....i took a GNX out for a guy with my laptop just to make sure it was running o.k. and his stuff lit up ON whenever the car shifted into 3rd and 4th, i don't remember seeing his TCC ON....could it be because the chip that i use locks the convertor up....i'm confused....also i have a fast update chip ( whatever that means ) and it seems like a million codes like....
Maf Sensor Low
IAC and/or idle speed error
EST monitor line failure
Exhaust Lean Condition
Fuel Pump Voltage Low
another time i got
MAT sensor voltage low
Vehicle Speed Sensor
Wastegate pulses absent
EGR diagnostic circuit
MAF sensor low
Cam sensor failure
Water Injection Failure
what's going on...the car doesn't run any different.....i don't understand...i am trying to tune this thing for the street but there are so many parameters you have to line up...but i'm not giving up...
also...ken mosher i emailed you about getting the password to update tlink to the newer version and i didn't get a response...not upset or anything just thought i would post it since you probably check this everyday....
TCC
3rd
4th
P/N
Maf Sensor Low
another time i got
MAF sensor low
Cam sensor failure
