REGALTURBO
I Am The Master..Master..
- Apr 20, 2003
Replacing my fuel tank. Since the original units are no longer available I had no choice but to go with an aftermarket. I noticed that it doesn`t have the plastic baffle inside as the original did. There is one there but it is a metal baffle and slighly lower. Will there be a differance in performance of any sort?
Also, replacing my walbro340 with another. I noticed that the pump housing of my new walbro340 has a foamy/rubbery black material around it. I remember that the first one I put in had the same thing but when I pulled it out it appears as though it disinegrated. Should I keep the rubbery material on the pump housing or remove it before I drop it in?
