Well now I'm on the fence, but you will be my first pm if I do.I agree with Pronto, not really a gain for the money. But if you do it anyway I would be interested in your dequick.
Stock bottom/cam. Champion heads/portmatched Champion intake/alky/5.7 chip for alky/70mm TB. It's always bothered me with the reducer coupler hoses. I figured at some point I could get everything to 3 inch for a nicewe have run both .. What is done to your car ?? How fast you looking to go ?? Oh we used the V4s in both the cars in my sig.
I will. The precision is just too big of money for now. Thanks guys. I must stop my brainstorming, lol.Leave the V4 alone.. Of course this is just my opinion.
Sometimes I just set and brainstorm.
I never thought of it that way. I actually figured the opposite.Measure the total length of all your 'undersized pipes'. Then take the 4.9 square inches of the 2.5 pipes then bump it up to 7 square inches for the 3" pipes. Multiple that by the length, then....
All the additional square footage will give you a guess on how much longer it'll take to get boost at the intake valves.
Yep. Boost is a compression wave that starts at the turbo and ends at the intake valve. Bigger pipes are only good if the current pipes are a restriction.
Otherwise it's just extra area that has to be compressed before the engine gets it.
The easiest way to decide on an upgrade is by the ''chasing the cork'' method. Somewhere between the air filter and the exhaust tip is one section that's the most restrictive. That's where to concentrate.
When that cork is addressed, a new one appears.
Cycle repeats itself.
