Would there still be a need for NOS?
Can't look up the specs right now but remember that ss will expand more than mild steel as it heats up so keep the shaft loose when cold.
More than likely I'll use a wastegate actuator to control the unit. I can hook up a regulated pressure source on the bench to check the action of the unit before I install it. I'll make sure to make a video.I wonder if you could put a TPS sensor on it somehow (and away from the heat) to log it's opening and closing habits?
I'll do that. Good idea.When you get it together you might see about adding some anti seaze to the shaft when you put it together. It might just burn off but some of it should stay and help the shaft to move.
The plan is to have it crack open at 8 to 10 psi. Do you remember what the stock nonadjustable starts to move at?The wastegate you see in those pictures I posted is a stock nonadjustable TR wastegate. I'm sure if you got a high boost adjustable unit it would work better.
