- Jun 18, 2001
I am completely re-doing my GN and will have a lot for sale. Some of it like the rearend is still on the car to keep it rolling. The following parts were used on my TSO car and have been 1.23 60' on old school drag radials at 3450#. The car routinely sixty in the high 1.20s
9" Ford Moser housing and axles with backbrace, fill/drain plugs, stock length with stock control arm mounting, spherical UCA bushings, gloss black powder coated with coil over brackets. Moser 35spline axles with 5/8 studs and rear disc brakes that include parking brake assemblies. Rearend is dirty in pics but cleans up like new and powdercoating is in excellent shape. Center section is NOT included but can be at additional cost. I prefer PU or delivery to the NATs in BG in May. I will ship at buyers expense. $1400
HR Parts rear ARB for 9" Ford rear $385
HR Parts Extreme Upper and Lower adj rod end control arms $500
QA1 rear coil overs single adj with custom valving and shock dyno sheets $350
TRZ front LCA for factory coil spring or with CO conv. $375
QA1 front single adj CO conversion with custom valving and shock dyno sheets $375
RCI 10 gallon Alum fuel cell with sending unit. Foam in excellent condition $150
Weldon 2035 with pre and post filters $650
