- Aug 1, 2003
normally connector A (two wire metripak plug end under hood ) is your primary pump ..that connector gets the mate connector with the wire looped between both terminals so that the relay for it triggers when ecm commands it
the B connector controls the second pump B . normally it gets the wire from the hobbs switch so it only runs under boost
to rotate the use of pumps just move the loop connector at A to B and the hobbs wire from B to A
the other two prong plug under hood is for power led and if not using should have a connector plugged in with no wires just silicone plugs ,
,the kit came with extra terminals and plug ends to add wires to the connector
